Configuring Load Balancing using NGINX
This page provides information on how to purchase training for this course. It includes a description of the course, suggested prework, any required prerequisites, and links to purchase based on modality.
Key Info
COURSE ID:
NGINXUniv-E-25
PRODUCT FAMILY:
NGINX
TITLE:
COURSE LEVEL:
Core
MODALITY:
Self-Directed Training (SDT), Instructor-Led Training (ILT)
LENGTH (DAYS/HOUR):
ILT - 1 Day
SDT - 6 Hours
LANGUAGES:
English
PRICE ($$/TU):
ILT - $1320/22 TUs
SDT - $480/8 TUs
CONTAINS HANDS-ON LABS?:
Yes
SDT details
Configuring Load Balancing using NGINX is a hands-on exploration of NGINX HTTP and TCP/UDP load balancing. Configuring Load Balancing using NGINX begins with a general review of load balancing, and an introduction to load balancer configuration, selection algorithms, and weighting in NGINX. After you configure an upstream, you explore options for session persistence and enable extended status / live activity monitoring. You implement TCP/UDP load balancing with active health checks, and configure routing and IP sourcing. We demonstrate a highly available (HA) NGINX systems in case of node failure. By the end of the class, you will be able to deploy a high performing (ADC) application delivery controller using NGINX Plus and its features.
AudienceThis course is intended for systems administrators or systems operators who will have responsibility for the management and ongoing operations of NGINX Open Source and/or NGINX Plus systems providing secured Web services.
This course presents the foundational understanding of NGINX systems for those continuing on to other NGINX-based services such as NGINX Caching, NGINX Load Balancer etc.
ILT details
NGINX Load Balancing is a hands-on exploration of NGINX HTTP and TCP/UDP load balancing.
NGINX Load Balancing begins with a general review of load balancing, and an introduction to load balancer configuration, selection algorithms, and weighting in NGINX. After you configure an upstream, you explore options for session persistence and enable extended status / live activity monitoring. You implement TCP/UDP load balancing with active health checks, and configure routing and IP sourcing. We demonstrate a highly available (HA) NGINX systems in case of node failure. By the end of the class, you will be able to deploy a high performing (ADC) application delivery controller using NGINX Plus and its features.
Prior Knowledge
Before taking this course, make sure you have completed one of the following:
The course assumes a basic understanding of networking, web servers, HTTP, load balancing, caching, proxying, and related concepts.Hands on labs are performed in a Linux environment. You will need to be able to navigate the file system from the command line and edit configuration files using VI/VIM. Additional experience with Linux environments will be helpful.
Register for your course
To view and/or purchase the SDT Course click here: View SDT Please find below the current active sessions for the ILT. If there are no sessions listed below and you would like to register your interest in attending the ILT version of this course please email: support@mail.education.f5.com
